October 4, 2017 at 12:20 pm
Vishal Ganore
Ansys EmployeeThe Euler Cell Over Emptied warning message indicates that a large volume fraction of a material ( > 0.9) is being transported into or out of an Euler cell in a single time step. AUTODYN issues this message to notify the user of potential numerical error caused by transporting excessive material in a single time step. The following recommendations may help alleviate this issue. 1. Use Internal Energy Transport (Global -> Transport). The AUTODYN default is Total Energy Transport. However, in explosive detonation calculations where the detonation products escape into a void at high speed, a better result may be achieved using internal energy transport, because that approach provides a more accurate determination of the internal energy in a cell, which in turn is then used in the explosive equation of state. 2. Increase the minimum Euler density (Material -> Modify -> Cutoffs). The escaping detonation products are typically at very low density. It is useful to limit the diffusion of extremely small masses by increasing this cutoff value. 3.Use a Maximum velocity cutoff of approximately 10,000 m/sec. The predicted velocities of very small masses of material escaping into a void can sometimes be unrealistic. You can limit this behavior by setting the Maximum velocity cutoff using Global -> Cutoffs.
October 5, 2017 at 11:39 am
Vishal Ganore
Ansys EmployeeIn Explicit Dynamics, why is the "Euler Cell Over Emptied" message issued?
- How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
- Can I define springs with coincident nodes defining each end? Can I use one spring element to define
- Check
- If SCDM issues the message “Cannot open the document. Reason: Failed to load body geometry.” and the
- Any suggestions on speeding up convergence behavior with surface-to-surface radiation?
- In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
- What is cause of error: display time for result item greater than the step end time?
- While projecting surfaces/curves onto cylindrical surfaces, the final shape sometimes deteriorates.
- How can I do a response spectrum analysis using more than 10,000 modes? The current solver limit is
- Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane windo
2656
2116
1339
1118
461
