January 21, 2022 at 2:47 pm
Jungsoo
SubscriberIn Maxwell3D, i used "Smooth" function in General tap in field calculator,
Could you explain about "smooth" function what it means mathematically?
it's not supposed to be an ordinary gaussian filter...
January 31, 2022 at 3:49 pmPraneeth
Please note that the answer to this post is being provided in the following thread - about "Smooth" function at general tap in field calculator ÔÇö Ansys Learning Forum.
Kindly refrain from creating such duplicate posts in future.
I am closing this thread to keep the sanity in the forum.
All the very best.
- Maxwell, HFSS or Q3D?
- Error
3772
2573
1825
1242
598
