April 24, 2021 at 9:07 pm
srep123
Subscriberlooking at literature i am provided with shear relaxation modulus ratio, is that the same.? if not how can i find the relative moduli, tried searching for it but can't find much about it.nAny help would be greatly appreciated,nthank you.n
Simulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
- Fused deposition modelling , part simulation for residual stress
- Symmetry model
- Membrane element problem in soft pnuematic actuator (artificial muscle)
- What is incompressible material and what the examples of incompressible materials?
- Why the stresses from shell elements are higher or lower than the stresses from solid elements
- Convergence issue in non linear problem
- /Contour Function on Mechanical APDL
- Why am I getting the “the requested S data is not available the PLNSOL command is ignored” warning
- How to 3D print impact tested materials
- Why is the deflection for my analytical solution not matching ANSYS results
613
562
220
188
128
© 2022 Copyright ANSYS, Inc. All rights reserved.
