July 9, 2021 at 8:19 pm
William_J
SubscriberIn Spaceclaim I am not able to enter decimal numbers when entering the length of a dimension in the properties window. 45.3 becomes 453 etc. Has anybody come across this problem? Is there a known solution?
Thanks for any suggestions
William
July 12, 2021 at 7:31 am1shan
Ansys EmployeeThis might be because of your windows setting, it uses 'comma' instead of 'dot' as decimal seperator. Check https://forum.ansys.com/discussion/1778/decimal-separator
Regards Ishan.
July 14, 2021 at 9:00 pmApril 13, 2022 at 8:51 pmrandyd
SubscriberSame issue with me today. I am creating a new sketch in SpaceClaim with dimension of 3.2mm, but not accepting it instead it gives 2mm.
I already checked my settings for "dot" and "comma" but to no avail.
How can i use the program to solve complicated things when i cannot even enter a simple decimal point in the Ansys program.
Im using 2021R2. Randy
April 13, 2022 at 9:39 pmpiknockyou
Subscriber,check out the link I posted. It was a Language setting for me.
April 16, 2022 at 6:56 amrandyd
SubscriberLanguage setting was US english, and di not solve the issue.
Viewing 5 reply threads- You must be logged in to reply to this topic.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2726
2156
1359
1150
462
