In SpaceClaim, when I take section of the assembly, it is not recognizing all parts. How to identify
October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeThis is probably due to corruption in the geometry. To identify the issue, exit the section mode. In structure tree, go to body which was not recognized in section mode. Right click on the body and select 'Check geometry' option. This should highlight any corruption in that body. Remove/Repair the corruption.
Viewing 0 reply threads
Trending discussions
- How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
- Can I define springs with coincident nodes defining each end? Can I use one spring element to define
- Check
- If SCDM issues the message “Cannot open the document. Reason: Failed to load body geometry.” and the
- Any suggestions on speeding up convergence behavior with surface-to-surface radiation?
- What is cause of error: display time for result item greater than the step end time?
- In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
- While projecting surfaces/curves onto cylindrical surfaces, the final shape sometimes deteriorates.
- How can I do a response spectrum analysis using more than 10,000 modes? The current solver limit is
- Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane windo
Top Contributors
2616
2098
1323
1108
461
Top Rated Tags
