In what co-ordinate system discrete phase(DPM) is calculated in axisymmetric model?
    • pmjsjs
      I'm using a 2D axisymmetric transient model. It is a two-phase model, where the primary phase is air and the secondary phase is discrete particles modelled using DPM. During the simulation, when the particle hits the axis it bounces back from it. So, to understand the particles' position I plotted the particle position graph via 'Particle track' under the result section. I plotted two graphs; 'Particle Y position' and 'Particle Radial position'. For the 'Particle Radial position' plot, the particle bounces back from the axis and continues its trajectory. But for 'Particle Y position', the particle seems to cut through the axis without bouncing(reflecting).
      Since I'm using an axisymmetric model is it possible for the particle to cross through the axis? If so, what co-ordinates DPM utilizes even though the model is axisymmetric?
      Thanks.
      Can you post the results?
    • pmjsjs
      I have posted the plots below.
      Thanks.
      Odd as it's behaving here.
      Can you post an image of the model? What does the Scale Mesh panel look like?
    • pmjsjs
      Thanks for the response.
      The model image is posted below.
      the mesh scaling image is posted below
      Thanks.
      Can't see any reason why it's not working from that. How big are the particles?
    • pmjsjs
      Thanks for the response. The particle's size is 500microns.
      Thanks
      Which is many times the size of the cells. Try a small particle and see what that does. Then read the background theory on the DPM model.
    • pmjsjs
      Thanks for the response. I will try it.
Viewing 8 reply threads
