June 12, 2019 at 7:41 am
June 12, 2019 at 7:58 am
Naresh Patre
Ansys EmployeeHello Roberto
The concerned team is actively working on to fix this issue. I will let you know as soon as it gets resolved. Meanwhile, did you try deactivating and then activating again from the command prompt using commands mentioned in this post? Let me know if it is not working.
June 14, 2019 at 8:03 am
rg
Subscriber -
June 14, 2019 at 8:45 am
Naresh Patre
Ansys EmployeeRoberto
From the error messages, it appears that you are specifying device ID in the activation command and not the activation id. You need to specify the activation ID which starts with "Act-" after -ActivateLicenseEntitlement command. You can see the activation ID mentioned below the start and end dates.
June 14, 2019 at 8:57 am
rg
SubscriberNaresh Patre Thank youuuu
June 14, 2019 at 9:19 am
rg
SubscriberRoberto Hi
Even so it doesn't work because anyway there are all the spaces involved in the license and I can't dissociate them even with the promt of the commands.
It doesn't matter, I'll wait for the server to work again
Regards
June 12, 2019 at 8:29 am
rg
SubscriberHi Naresh, when it usually doesn't work I'm always using the command prompt but now this doesn't work
Regards
June 14, 2019 at 2:56 pm
Naresh Patre
The server issue has been fixed and the activations can be released from the account page. Please let me know if you still see any issues.
June 17, 2019 at 9:39 am
rg
SubscriberHi Naresh Patre
now everything is back to work
3862
2639
1859
1254
600
