Inability to save Fluent calculation/simulation
    • k.m.vanderkleij
      Hello all,
      I have been attempting to simulate a cooling system, however, upon exiting the Fluent program after having done the simulation I receive the following error:
      Error: access: unbound variable
      Error Object: set-var!
      This error prevents me from going back into the workshop and opening the results since it detects a "partial save". This prompts me to reload the save from before entering the mesh into Fluent.
      Now, I find this error quite vague. Is there anyone that can point me in the right direction where I need to look in order to solve this error?
      Thanks in advance.
      Assuming there aren't any "odd" characters in the path or file name try exporting case & data and opening Fluent in Standalone mode.
      • k.m.vanderkleij
        Thanks, I will attempt that and get back to you!
      • k.m.vanderkleij
        For now this seems to have worked! Thank you very much for the help
          Test - checking functionality
      Good to hear.  Not sure why it's happening though. Which version of Fluent, and are you saving with legacy or h5 format?
