June 1, 2020 at 4:28 pm
Ruan
SubscriberHello, I encountered some errors when simulating the frictional heat generated from the frictional contact pair. I have just defined the FWGT and FHTG with APDL command, and the reference temperature was set as 25. As shown in the following solver output, it reminds me the thermal loads were inappropriate, could you kindly tell me how to fix this problem?
*** ERROR *** CP = 12095.422 TIME= 18:04:11
Some of the element based thermal loads may be inappropriate. Check
applied element loads carefully. Ensure that film coefficients and
bulk temperatures are always positive.
August 15, 2020 at 9:45 am
emad0098
Subscriberhi ruan.ni'm having the same problem. did you manage to find any solution to this?n -
August 24, 2020 at 8:54 pm
SaiD
Ansys EmployeeHi,nHere is a relevant thread that might help:nHi,nHere is a relevant thread that might help:nHope the suggestions are helpful,nSain
3862
2639
1859
1254
600
