Incomplete plot’s range when runing fleunt on linux
    • Amir
      I have run a fluent case on batch mode on linux, after finishing the calculation and when I try to import the data and plot the reports, the horizontal axis is covering only a partial part of the data. The physical time of the simulation is 900s, but the plot only covers from 855 to 900s. The report files contains all data, but plots do not. The problem happens for all report definitions that I defined, however the plot of residuals does not have this problem. Does anyone have any idea what is the problem?
      Forum Moderator
      How is the plot x-axis defined?
      • Amir
        I am not sure if I understood what you meant Rob, can you please clarify a bit?
        I tried unchecking the "auto range" for x-axis, now the length of axis is covering the whole range, but there is no data ploted for 0 to 855s.
      Forum Moderator
      Odd, I've only ever seen that where the data wasn't available due to files not being saved, or monitors being set after the run reached a certain time.
      What do you see if you plot the data in Excel?
