September 6, 2019 at 1:39 pm
naada
SubscriberHey
Can someone please write me the Navier stokes equations for both models of incompressible ideal gas and ideal gas so I can understand the difference?.
Thank you -
September 6, 2019 at 2:31 pm
DrAmine
Ansys EmployeeWhy you need the NS for that? Ideal Gas EOS density=actual pressure/(Gas Constant*Actual Temperature), incompressible ideal gas density=p_op/(Gas Constant*Actual Temperature.)
What is the problem you are facing?
September 6, 2019 at 2:43 pm
naada
SubscriberI read in one of the websites that in the ideal gas case energy and momentum are coupled but in case of incompressible ideal gas they are not how this can be possible in case of natural convection?. Like what is the effect of choosing incompressible ideal gas over ideal gas?.
Best Regards;
Nada -
September 9, 2019 at 5:28 am
DrAmine
Ansys EmployeeIncompressible ideal gas is to account for weak compressible gases where temperature dependency is important. Ideal gas is for compressible gases and acciubt for temperature and pressure dependency.
Enclosed heated cavity: you get mass defect if use incompressible ideal gas as pressure ruse due to heating won't be felt in the density calculation
2726
2146
1357
1150
462
