October 29, 2023 at 11:02 am
yarykgv
SubscriberHello everyone, the other day I went through one of the lessons on using Ansys Fluent - https://courses.ansys.com/index.php/courses/cfd-in-aero/lessons/commercial-aircraft-propulsion-thrust-from-a-convergent-nozzle/
I did everything right and got the same result as in the lesson:
But I decided to check the coefficients from the "Results and Discussion" section using the same formulas and nothing matched:
The problem is that I can't understand what I calculated wrong. I assume that I do not correctly understand some physical quantities in the formula.
Task input -
October 30, 2023 at 12:41 pm
Federico Alzamora Previtali
Ansys EmployeeR is the air specific constant of R_air = R_universal/M_air = 287 J/kg/K, not the universal gas constant.
October 30, 2023 at 7:12 pm
yarykgv
SubscriberThank you very much. Now everything is correct.
- ANSYS License Manager Error
- Your product license has numerical problem size limits…..
- Acoustics model in Ansys 18.1
- Download 2019 R1 Student Products
- Minimum requirement
8770
4658
3151
1678
1456
