March 18, 2022 at 9:28 am
Jeon
SubscriberHi,
I am trying to compare Poynting vector (P) with the value calculated using E and H.
First, I found that the results of the two expressions below are different.
(light traveling in the z direction, monitor located in free space)
March 18, 2022 at 8:19 pmGuilin Sun
Ansys EmployeeYou would not be able to get Ex/Hy=eta0 =377 since this value is valid for plane wave only in vacuum. Now you are simulating a nano scale structure, the fields you obtained are not plane wave. Please think it over. I would suggest that you simulate vacuum only by disabling the nano structure, and verify this value. Please note that when the textbook gives 120Pi, it is for real valued plane wave E and H fields.
March 21, 2022 at 9:49 amJeon
SubscriberThanks for the reply.
However, my simulation results were sufficiently uniform plane waves. Sorry for not giving you enough information before.
Even when a film of the same height as the nanostructure was placed instead of the nanostructure array, the same result was obtained.
Fortunately, in the process of checking it, I think I found the reason. Increasing the mesh auto accuracy level made the difference significantly smaller.
Even when the level is low, Ez at that point (or plane) is almost zero and it is a sufficiently uniform plane wave (compared to the error). So I don't think I've found a clear reason yet, but I found a solution anyway.
Thanks again for your reply, and any additional comments would be appreciated.
March 21, 2022 at 7:30 pmGuilin Sun
Ansys EmployeeYou are right that with higher mesh accuracy the result can converge.
For the field profile from monitor, although it seems uniform, it is not as only two digits are shown. if you use min and max, it can show you the difference.
It seems your result has imaginary part of the impedance, than it means E and H are not phase matched, eg, not a simple plane wave. If you test a free space, you may find more info.
I did a test with mesh accuracy 2, and using the following script:
E=getresult("monitor","E");
H=getresult("monitor","H");
eta=E.Ex/H.Hy;
?min(eta)/(120*pi);
?max(eta)/(120*pi);
The E and H fields are much more uniform:
but the min and max are
1.01535
1.0508
The error is mainly from discrete mesh: E and H are not located at the same position in Yee cell internally. The output is the result of interpolation, which can introduce additional error also.
March 22, 2022 at 10:52 amJeon
SubscriberNow I have a clear understanding of the reason for the difference.
Thank you so much for your reply.
Viewing 4 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2524
2066
1279
1096
457
