Photonics
Photonics
Incorporating Pancharatnam- Berry Phase into the script
    • akshaybabu1999
       I was going through the paper  "Metalenses at visible wavelengths: Diffraction-limited focusing and subwavelength resolution imaging" And I am trying to simulate a metalens with rectangular pillars. I read about the P-B Phase condition for the circularly polarised light. I am not able to incorporate the P-B condition into my script for the correct Phase vs angle of rotation graph. Can anyone please explain to me how it's done?
    • Guilin Sun
      If the phase is space dependent, you will need to create a such source with the phase. Please refer this example: https://optics.ansys.com/hc/en-us/articles/360034383054-Using-an-equation-to-define-the-spatial-field-profile-of-a-source-in-FDTD
      The source amplitude can be uniform or also space dependent.
    • A.Abdur Rahman Akib
      Did you find a way to incorporate it?
    • Guilin Sun
      As long as you have analytical expression or computed data for the phase, you can import them by referring the above example.
Viewing 3 reply threads
