May 19, 2019 at 3:39 pm
davidp
SubscriberHi Support Community,
I have a simple circular cylinder at Re 30000 but when i ask to plot drag coefficient the value is always ending around 10 instead of around 1-1.2. The value drops initially to around 3 but recovers to the higher value before convergence. The value is almost perfect a factor of ten high but I'm not convinced it is a calc error. I have checked units and they are all SI.
I presume my setup is wrong but I have no clue where it is and a little frustrated.
I have a high mesh count as I'm trying to get a Y+1 solution, the problem is 2D steady, I'm using k omega SST and PISO with increased skewness correction iterations and hybrid initialization. I have used other solvers as well but they all give around the same answer at convergence so clearly its something I've input.
Any ideas on what I've got incorrect would be greatly appreciated.
Cheers
David
May 20, 2019 at 4:35 am
Amine Ben Hadj Ali
Ansys EmployeeCheck your reference values as they are required to calculate dynamic pressure at farfield. -
May 20, 2019 at 5:49 am
davidp
SubscriberGday Amine,
Thanks for your response. Greatly appreciated.
I have adjusted the reference values to the same as the domain values for vel, viscosity and density and now the Cd is too low, argh any ideas.
David
May 20, 2019 at 6:39 am
Amine Ben Hadj Ali
Ansys EmployeeYou need to adjust to the inlet values or the reference values from the literature. Ensure for a deep converged run. Ensure that you a yplus in the viscous region a reasonable number of cells to resolve the boundary layeer (not less than 10).
- The topic ‘Incorrect coefficient of drag for circular cylinder’ is closed to new replies.
- How do I get my hands on Ansys Rocky DEM
- Unburnt Hydrocarbons contour in ANSYS FORTE for sector mesh
- Script Error
- Help: About the expression of turbulent viscosity in Realizable k-e model
- Facing trouble regarding setting up boundary conditions for SOEC Modeling
- convergence issue for transonic flow
- Point exception in erosion calculation
- Errors with multi-connected bodies using AQWA
2122
918
599
591
483
© 2025 Copyright ANSYS, Inc. All rights reserved.
