March 9, 2021 at 7:24 pm
ecrod
SubscriberI am trying to use a named expression as velocity boundary condition at inlet. My expression is working fine as you can see in the plot.
March 9, 2021 at 7:28 pmYasserSelima
SubscriberHow is u_a, u_b and u_p defined?nMarch 9, 2021 at 7:39 pmYasserSelima
Subscriberby looking back at the photos you provided, it is a matter of defining real and integer.nnGo to u_a definition and make the units [m/s] ... do not have 1.000. Same for u_b and u_pnMarch 10, 2021 at 2:19 amMarch 10, 2021 at 2:42 amYasserSelima
Subscribertry thisnu_vel * 1 [m/s] / 1 [m s^-1.000]nlet me know if it worksnMarch 10, 2021 at 4:14 pmecrod
SubscriberHello Yasser,nIt does not work. This problem is due to Herschel-Bulkley consistency index definition K [Pa*s^n] in named expressions, because the flow index n = 0.34 is real number.nProbably it is not possible to use the above velocity equations using Named Expressions, maybe only UDF. However, I do not know anything about UDF.nThanks.nnMarch 10, 2021 at 10:14 pmecrod
SubscriberThe solution was to use everything dimensionless, included Y coordinate. In the end I used only u_vel [m s^-1] unit.nThanks your help Yasser.nMarch 11, 2021 at 1:14 amYasserSelima
SubscriberYou are welcome. I was actually into suggesting this but I thought it is less hassle to try changing the units first nMarch 11, 2021 at 6:54 amDrAmine
Ansys EmployeeThanks for getting back with your solution. Yes I recommend to keep things dimensionsless when running into troubles or to correct at least the output by just adjusting the units as I think checking the whole parts of the formula might be complicated.nViewing 8 reply threads- You must be logged in to reply to this topic.
2656
2120
1345
1118
461
