December 12, 2019 at 10:23 am
paul
SubscriberHello,
When inserting a detail view, some lines that are out of bound in the detail view still popup. This should not be possible.
Also, if you look at the section view before you create a print or print preview, the lines in the section view are not visible. After creating a print or print preview they show up. Unless i am mistaken, this should not be correct.
Can these issues be fixed?
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions -
December 12, 2019 at 12:04 pm
Subashni Ravichandran
Ansys EmployeeHello Paesc
Thank you for reporting these issues. I am able to reproduce them.
Similar bugs have been reported before. I will check with the team and get back to you on this.
December 18, 2019 at 12:29 pm
The Bug number is 20582. Although it is a rather old issue, it has not been resolved. I have sent an enquiry. I will keep you posted as I hear from the team.
3930
2649
1865
1272
610
