March 31, 2022 at 10:32 am
mu
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
on some geometry in 2D view outer thread are not represented correctly.
As you can see in below image some lines are missing in several view.
I already tried to create a new design with a new model, but also in it the drawing view problem is present.Â
After some test it seems to be related to the chamfers on the edges where the thread is applied.
Attached you can find the file of example.
Can you verify the cause of this behaviour and how to obtain the correct representation?
Thank you in advance,
Marco Ugolotti
March 31, 2022 at 11:14 am
Devendra Badgujar
Ansys EmployeeHello Marco Ugolotti
Let me check and get back to you on this.
Regards.
March 31, 2022 at 2:13 pm
Devendra Badgujar
Ansys Employee-
March 31, 2022 at 4:43 pm
mu
Thank you Devendra Badgujar for your quick answer.
I've already noticed that in wireframe mode all lines are visible, but, as you can simply imagine, for complex drawing wireframe cannot be used.I attach another example to highlight a "strange" behaviour: changing chamfer dimensions and body rotation the lines shown are different
body rotate of 45°
Â
Best regards,
Marco
April 1, 2022 at 5:22 am
Devendra Badgujar
Ansys EmployeeMarco UgolottiÂ
I will check this and get back to you with more information.
April 4, 2022 at 7:19 am
Devendra Badgujar
I checked with the development team and they said that it is a bug inside Hidden Line engine. Depending on the model orientation, Hidden Line Removed outputs incorrect edge classification (visible vs hidden) Â
A possible workaround is to try different thread display standard (so that thread display will look consistent).
 This is the same issue with the Hidden Line engine.
- loss of user settings
- Can’t see license on online account
- Copy user settings to new release
- help online
- Unexpected graphics error
- Electric Heating – Ansys AIM
- Dwg export error
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- Natural frequencies limited to first 6 modes
- Discovery AIM Mesh Error
3744
2573
1817
1236
594
