Discovery Import
Discovery Import
increase in rights
    • omajo
      hello,
      I just received an email from a customer who is trying to solve his license refresh problem.
      here are these words:
      'I just did the manipulation on the station with an increase in rights.
      I have a certificate error.
      I will attach the log file with the errors.'
      see the attached file .
      Best regards
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Subashni Ravichandran
      Hello olivier. majo
      Does the customer ave proxy settings in place?
      If so, can you please guide them to go through point #5B in the Troubleshooting Document.
      If that does not work can you also try point #5D.
      Please let me know if this helps.
      • omajo
        Subashni
        hello, here is the answer of my client
        'I don't have a proxy.
        It is at the heart of the network, so there is no configuration to do on the workstation.
        I have already done the test for the certificate and it is present on the workstation.
        The problem is elsewhere.'
        regards
      Hello olivier. majo
      Could you please ask the customer to share all the files as mentioned in #6 of the Troubleshooting Document?
      • omajo
        Subashni
        Thank you  Subashni
        my client is finally successful
        best regards
