October 4, 2017 at 12:20 pm
Vishal Ganore
Ansys EmployeeHow to increase the maximum number of equilibrium iterations per solution step in Mechanical?
October 17, 2017 at 10:28 am
cbhavsar
Ansys EmployeeThe maximum number of equilibrium iterations per each solution point is 25 based on the default setting of the NEQIT command. To change the maximum number of equilibrium iterations, you can issue the NEQIT command from within a Command Object. For example, issuing NEQIT,30 will increase the maximum number of equilibrium iterations to 30.
Trending discussions
Top Contributors
2600
2088
1319
1108
459
Top Rated Tags
