January 25, 2023 at 2:59 pm
David Zamora
SubscriberWhen I click "Analyze Results" I get an error: "Java heap space" and the recommendation is to "increase the memory available to the user interface". This is straight from the error message:
"To obtain twice the memory, specify
CKJAVAMEMORY=-Xms2048M -Xmx2048M ''
Where do I change this "CKJAVAMEMORY" value? I am not an administrator on my computer and I do not have Java installed. Please advise. -
February 1, 2023 at 1:43 pm
ANSYS_MMadore
Ansys EmployeeThis would be set as a variable in your user profile. You can approach IT about setting this so it is available whenever you login.
February 1, 2023 at 9:48 pm
David Zamora
SubscriberThank you for your response. I've reached out to my IT team and they've asked me to confirm that the variable name and value are the following:
variable name: CKJAVAMEMORYvariable value: -Xms2048M -Xmx2048M
Thanks again
2616
2098
1323
1108
461
