June 28, 2020 at 5:15 pm
ml44655
SubscriberHello,
I have been running steady state thermal analysis over the week. However, after trying to increase the number of cells in the mesh, I have run into a couple of errors (photos attached)
I am running it on Linux.
Thank you.
June 29, 2020 at 10:23 am
Ansys EmployeeThere's a limit of 32k nodes on the Student version, did you hit that?
June 29, 2020 at 5:20 pm
ml44655
SubscriberI am not using the student version. I believe my lab is using the research license.
June 30, 2020 at 12:57 am
tsiriaks
Ansys EmployeeClose all ANSYS applications, then rename the following folder to anything else
$HOME/.ansys/
If this doesn't help, can you try with different geometries/models and see if issue is persistent ?
June 30, 2020 at 1:38 am
ml44655
SubscriberI have tried renaming that folder as well as starting off with a new geometry. None of them work.
July 2, 2020 at 6:21 pm
ml44655
SubscriberHello,
I am still having this problem. Is there any way to get help on this issue?
July 3, 2020 at 1:26 am
tsiriaks
Ansys EmployeeWhat OS version is this ?
What is the output of the following command
cat /etc/*release
Check ANSYS Linux installation guide Chapter 2 and make sure you install all prerequisites for your OS version.
July 7, 2020 at 4:07 am
ml44655
SubscriberIt is CentOS Linux release 7.6.1810 (Core).
I will look into that.
THank you.
July 9, 2020 at 8:00 pm
tsiriaks
Ansys EmployeeWelcome. Keep us posted how it goes.
Simulation World 2022
Check out more than 70 different sessions now available on demand. Get inspired as you hear from visionary companies, leading researchers and educators from around the globe on a variety of topics from life-saving improvements in healthcare, to bold new realities of space travel. Take a leap of certainty and check out a session today here.
- Workbench not opening
- Workbench error
- License Error
- Licensing Error
- Error with lumerical license activation.
- ANSYS 19.1 installation on Linux
649
612
220
196
128
© 2022 Copyright ANSYS, Inc. All rights reserved.
