October 6, 2023 at 11:13 am
Alberto
SubscriberHi,
I'm trying to compute the sectional lift coefficient along spanwise direction. I've used the average force acting on the surface body using the force_z() function, then i'm trying to divide this value for a length, in order to get the distribution along a line. (is there any way to obtain this value differently? if yes, please tell me). then i did the same for the dynamic pressure, which I use as denominator in the lift formula. The problem is that in the dynamic pressure i've used the body (a rotating propeller) tangential velocity which is 0 in the center of gravity. This lead to a problem during lift coefficient computation becouse i'm trying to divide by 0 some quantity. How can i index the variable in order to avoid the zero values? Is this procedure correct ?
Many thanks
October 12, 2023 at 10:44 am
CFD_Friend
Ansys EmployeeHi Alberto,
Which formula for Cl are you trying to calculate?
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
