TAGGED: Induced-Voltage, inductance, maxwell-solution, maxwell3d
March 24, 2022 at 1:41 pm
rahelium
SubscriberHi everyone,
I'm simulating a three-phase single-sided linear induction motor with Maxwell (transient analysis). My final goal is to get values for the stator, rotor and mutual inductance. Under the results tab in Winding, I have the option to plot the self and mutual inductances of the individual phases. Is there a way to calculate the whole stator inductance out of it? And how do I get the the rotor and mutual inductance?
My idea was to do simulate no-load case (and at a later stage also locked rotor case) and extract the inductances via a T-model from the input voltage, input current and induced voltage. But I'm not sure what the induced voltage represents. I would want the induced voltage in the secondary but even when I simulate the motor without the secondary, I get a sinusoidal induced voltage? So if anyone could explain what this induced voltage actually represents, your help would be much appreciated, thank you!
March 30, 2022 at 1:50 amNavya C
Ansys EmployeeHi@rahelium Induced voltage is the combination of Inductance voltage due to flux linkage + Backemf.
Regards Navya
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7592
4438
2951
1427
1322
