Tagged: cosimulation, inductance, inductance-calculation, maxwell, simplorer
February 24, 2022 at 4:55 pm
arshiah
SubscriberHello,
I am trying to model an inductor with varying inductance (L) as a function of varying current (i) flowing through it.
In Maxwell, inductance matrix gives the L values assuming a 1A current flowing through the coil of the inductor by default.
- Can I measure inductance for different currents (other than 1A)?
- Can I model the same in Maxwell and co-simulate it with a power electronics circuit which can get variable inductance for different current flowing thought the circuit
Thank you
Arshiah
March 4, 2022 at 7:43 pmDeyu Li
Ansys Employeeyes, you can measure inductance with different excitation.
yes, you can use Simplorer cosimulate with Maxwell, TR to TR.
- Maxwell, HFSS or Q3D?
- Error
2616
2098
1323
1108
461
