Induction Core Temperature not rising
    • Asif Haq
      Hello.
      I am doing a induction coil and core heating simulation using a single coil. I have set the follwoing settings in maxwell
      Solver Setting - Eddy
      Eddy Effect - Core
      Customised bulk density for the core
      Transient Solver Setting
      Convection
      Load Imported from Maxwell
      Requirement
      Temperature
      This is the result i am getting. I tried increasing the time but it only increased by 1 degree. I am not sure what more to do here.
    • Asif Haq
      My expectation is to see the temperature rise upto 1000 degrees. I am not sure what is wrong here.
    • Asif Haq
      Project File
      I have set uploaded the file in the link above. If any one watns to check.
    • Ashish Khemka
      Hi Asif,
      What is the time taken for the temperature to 1000 degrees? Currently, it looks like the analysis is solved for 1 second.
      Ashish Khemka
      • Asif Haq
        I put in 20000 seconds as step end time. But stil does not reach
      • Asif Haq
        I put the following settings and now i am getting results. the temperature is going higher then expected
      • Asif Haq
        I know the scaling factor should be as close as possible to 1. How do i get around this.
Viewing 3 reply threads
