Ansys Products
Ansys Products
Inertia Properties of Point Mass – AQWA
    • Eugenio Baita Saavedra
      when adding a Point Mass to a geometry, you have to include the inertial properties (Radius of Gyration or Direct Input of Inertia). Must it be referred to the CoG of the Point Mass or to the Origin of Fixed Reference Axes (FRA)?
      Cheers,
      Eugenio
    • Ingrid Machecler
      Good morning, these mass properties are referred according to the CoG and the coordinate system (aka: x, y, z) is according to the fra.
      I hope this helps.
      Ingrid
      Thank you Ingrid,
      just for confirming, the inertia values must be for the axes that pass through the center of the FRA, not through the center of the COG of the Point mass.
      Cheers,
      Eugenio
      the other way around*
Viewing 3 reply threads
