August 20, 2019 at 10:13 pm
asamaiyar
SubscriberHi,
Are there Technical Notes about how Infinite Ground works with Master-Slave Boundaries in HFSS? Is it even recommended to use Infinite Ground option with Master Slave boundaries?
Thanks,
Aman
September 4, 2019 at 4:15 pm
slouie
Ansys EmployeeHFSS will solve for currents on the finite ground plane that you have physically defined in the model, but when calculating far fields, it will take into account the "infinite ground" option if you've selected it. In other words, radiated fields are the only result affected by the infinite ground option - the infinite ground option does not change what's happening during the HFSS solve process; only the radiated field calculations that occur after the solve process will be affected (like when you plot far fields for example).
September 4, 2019 at 6:57 pm
asamaiyar
SubscriberGreat. Thank you for the response.
Is it okay to use infinite ground plane with Master-Slave boundaries?
September 20, 2019 at 10:35 pm
slouie
Ansys EmployeeYes, that should be fine.
- Maxwell, HFSS or Q3D?
- Error
2590
2080
1315
1108
459
