TAGGED: boundary, inflation, inflation-layer, inflation-layers, wings
January 29, 2021 at 6:35 pm
jesus23
SubscriberI am creating an inflation where the scope is a body (blue in first figure attached) and the boundary is the wing surface area (second figure attached). When I am trying to select the different faces of the boundary, the same message after clicking apply appears in the yellow box: No selection. I tried to select only one face and then extend to the limits, I tried to select one by one every face but nothing changes.
January 29, 2021 at 6:47 pmjesus23
SubscriberUpdate: When I hide the body, I cannot select that ''inner part'' and, I can extend to the limits to the whole wing. However, it does not allow me to select these faces as the boundary.
January 30, 2021 at 12:27 pmKarthik R
AdministratorHi Try hiding the unnecessary faces (instead of an entire body). This would retain the faces you are looking for and should help you in your selections.
Thanks.
Karthik
January 31, 2021 at 10:10 amjesus23
SubscriberHi
The problem is not that I can not select the proper faces. I can, but the inflation boundary does not allow me to apply them.
Anyway, I tried and the problem is still there.
Thank you very much.
Jes├║s.
February 1, 2021 at 11:57 amjesus23
SubscriberIt┬┤is solved already.
February 1, 2021 at 4:02 pmKarthik R
AdministratorExcellent !! Good to know. To help anyone who is facing a similar issue, would you be able to post a short summary of how you resolved your issue?
Thank you.
Karthik
Viewing 5 reply threads- You must be logged in to reply to this topic.
5268
3299
2469
