January 6, 2019 at 3:45 pm
Beni
Subscriberhow to solve this massage?
January 7, 2019 at 9:16 am
Ansys EmployeeStair step is caused when there's no space to fit all of the inflation into the model, or there's a problem with an angle. If the mesh is OK then there's no need to fix it. Otherwise (with poor mesh) locate the problem area and work out why that's the case: if you add images into the post we can help as staff can't open attachments.
January 7, 2019 at 2:17 pm
Beni
Subscriberthank you sir rwoolhou for your respon.
my mesh is ok but any warning like this(inflation created stairstep mesh at some location & element volume exceeds the warning limit. small element volume was encountered)
And I don't know why I cant insert image in this discussion room
January 7, 2019 at 2:33 pm
Ansys EmployeeUse the "insert image" option. Not sure why element volume would trigger a warning, can you post an image of the warning too?
January 7, 2019 at 3:04 pm
January 8, 2019 at 3:53 am
Keyur Kanade
Ansys Employeeif mesh orthogonal quality is is ok then you can proceed.
make sure that min orthogonal quality is greater than 0.1
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1283
1096
459
