December 6, 2019 at 12:57 pm
December 6, 2019 at 7:20 pm
SubscriberSlice the geometry up into six-sided bodies and you can keep the hex elements.
December 10, 2019 at 9:41 am
bahar27
SubscriberI divided it into six-sided bodies and the inflation worked, but when I tried to do it for the second time it did not work anymore and the shape of inflation layers gets weird when I want to repeat the process or change something.
the procedure is as follows:
edge sizing, then the method which was multizone, and then the inflation and after all the face meshing for the center.
December 10, 2019 at 9:47 am
December 10, 2019 at 10:46 am
Ansys EmployeeThat's an O-grid or butterfly mesh. You may want to use a pave mesh in the middle rather than the decomposition.
December 10, 2019 at 11:30 am
bahar27
Subscriberthe inflation is not dependant on the face mesh in the middle, the inflation behaves weird when I change the order of edge sizing. Is multizone a good solution? and should I divide the geometry into six-sided bodies? is the order of meshing right? why the inflation gets weird(in pic 2)when I change something such as edge sizing?
December 10, 2019 at 3:03 pm
Ansys EmployeeEdge sizing will influence the face mesh, and is affected by the inflation. If settings conflict you'll get some weird (and undesirable) effects. My approach with Workbench meshing is to use as few local settings as possible, and instead use the global size settings (specifically size functions). More usually, I use Fluent Meshing and/or a lot of tet cells: depends on what you want to do with the mesh.
December 23, 2019 at 10:47 am
singh33
SubscriberDear rwoolhou,
Does the sequence of the local setting selected do affect the meshing?
Thanks in advance
December 23, 2019 at 3:31 pm
Ansys EmployeePotentially, yes. The order you mesh volumes has a greater effect.
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5290
3311
2471
