March 9, 2021 at 11:00 pm
ualac3
SubscriberHi GuysnI know inflation layers are used in turbulence modelling, but are these methods also valid for laminar flow? I've created a model initially based on turbulence but I have now discovered its laminar (change in characteristic length). Is it still acceptable/accurate to use inflation layers for laminar flow aswell?nThanks,nMichaeln -
March 10, 2021 at 3:43 am
Keyur Kanade
Ansys EmployeeFor laminar flow boundary layer is thicker. So coarse mesh at wall can resolve it. But it is good to have a boundary layer at wall. nPlease check nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communitynn
Trending discussions
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
