Inflation problem
    • jesus23
      I have set the inflation option over a wing (see figure) and near the leading edge suddenly all the layers start disappearing one by one. The boundary option I have selected ALL the faces, including obviously the leading edge so I do not understand what is happening and how can it be solved. I tried different inflation option ( pre, post, different layers, etc...) with the same result.
      I've closed the other thread to avoid confusion. nAre there any warnings in the Meshing tool regarding stairstepping? What settings have you got on the inflation mesh? n
    • Keyur Kanade
      Can you please upload more images for that area. nPlease check Mesh - Inflation - Advanced. Here please change angle to 170. nPlease check if all faces are correctly selected in inflation. nPlease check if there are any hard edges or points. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
    • jesus23
      I've closed the other thread to avoid confusion. Are there any warnings in the Meshing tool regarding stairstepping? What settings have you got on the inflation mesh?https://forum.ansys.com/discussion/comment/105143#Comment_105143
      Sorry for the delay. I attach the messages (nothing related to stairstepping) and the inflation settings.nI tried with another aerofoil and the results were the same.nn
    • jesus23
      https://forum.ansys.com/discussion/comment/105143#Comment_105143Sorry for the delay. I attach the messages (nothing related to stairstepping) and the inflation settings.https://us.v-cdn.net/6032193/uploads/1SNSMGXVPC3S/2-png.pnghttps://us.v-cdn.net/6032193/uploads/4CCAC3HESBO8/3-png.pngI tried with another aerofoil and the results were the same.https://us.v-cdn.net/6032193/uploads/0VHQUF2M9SIB/1-png.pnghttps://us.v-cdn.net/6032193/uploads/PCFMQ844MQBM/capture-png.pnghttps://forum.ansys.com/discussion/comment/107462#Comment_107462
      Here is the messages nn
    • jesus23
      Can you please upload more images for that area. Please check Mesh - Inflation - Advanced. Here please change angle to 170. Please check if all faces are correctly selected in inflation. Please check if there are any hard edges or points. Regards,KeyurHow to access Ansys Online Help DocumentHow to show full resolution imageGuidelines on the Student CommunityHow to use Google to search within Ansys Student Communityhttps://forum.ansys.com/discussion/comment/105298#Comment_105298
      It is solved changing to 170 degrees. Thank you very much!!!nn
Viewing 5 reply threads
