March 26, 2021 at 7:54 am
jjwon2
SubscriberI'm having problems meshing my 2D geometry. I have an inflation with the following settings:nInflation option: First Layer ThicknessnFirst Layer Height: 1.9e-6nMaximum Layers: 30nGrowth Rate: 1.2nThe mesh results in only about 14-16 layers, and I'm not sure why. I also tried the Maximum Thickness option with 30 layers again, and I got the same result. What could be reasons why this is happening?n -
March 26, 2021 at 10:08 am
Keyur Kanade
Ansys EmployeeIt must be stair stepping. Please check the geometry near the edges on which inflation is defined. Also please check if all required edges are defined under inflation. If some are misssing, then also it will create stairstepping. nPlease search stairstepping and you will get many discussions on this forum. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
Trending discussions
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
Top Contributors
2524
2064
1279
1096
456
Top Rated Tags
