Discovery Import
Discovery Import
Information
    • rg
      Hi   It often happens that we save files with the table closed, but when we reopen the file the table opens. Can this be avoided in any way?   Best Regards
    • Charudatta Bandgar
      Hello Robert ,
      Can you please share a screen-recording of this if possible, it will be easier to understand?
      Regards.
    • rg
      Hello Charudatta Bandgar Yes of course, I am sending you a video. When I have an assembly where I have created a table, before closing spacecliam / the file I close the mechanical drawing and then save. (As in the video). In such a way that the next time I go to reopen the file the table will not open. This is to avoid major delays when opening a large assembly with a detailed table. The problem that even if I save the file with the table closed, when I go to reopen it sometimes it opens it to me with the table and other times not randomly   Best Regards
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      Hello Robert , If I understood correctly, you want the drawings created not to be opened when you close the drawing window and save the file. (Steps used: 1. I created a drawing document for a  geometry file. 2. Closed the drawing window. 3. Saved the file and closed the file. 4. Reopened the saved file.) When recreated these steps (Please refer to the attached video), the drawing document did not open. Is this what you were referring to? If yes, I will check if there are any settings that are active, and will let you know. If this is not the issue you are referring to, please let me know.   Regards.
      • rg
        Charudatta Bandgar Hello
        Yes, you understood what I said.
        I want it to behave the same way you did in the video.
        When I go to reopen the file I don't want the table to open.
        It often happens that if I perform the procedure you showed me, the table opens anyway and this involves a big slowdown
        Best Regards
    • rg
      Do you have any news regarding this problem
      Best Regards
        Let me get back to you, Roberto
        Since I could not see that happening on my end and I can't seem to find any settings otherwise.
        Regards.
Viewing 4 reply threads
