Discovery Import
Discovery Import
Information
    • rg
      Hi
      Will there be an option to adapt icons to 4k monitors in the next version, so that the icons don't get much smaller?
      Best Regards
    • Naresh Patre
      Hello Robert
      I am checking with the team and will let you know.
    • Naresh Patre
      Hello Robert
      Currently, 4K is not technically fully supported with SpaceClaim. But below are some recommendations to configure SpaceClaim with 4K display:
      All you should need to configure SpaceClaim with a 4K display is the "high DPI scaling behavior" setting. To do this (once you have the 4K display in place):
      - Right-click the SpaceClaim desktop icon.
      - Go to Properties.
      - Go to the Compatibility tab.
      - Click "Change high DPI settings."
      - Check the “Override high DPI scaling behavior” box.
      - Select the “System (Enhanced)” option that becomes available after checking the override checkbox.
      In addition to the above settings, Go to your Display settings (windows display settings) and set the 4K monitor to be your main display. Then, you can adjust/experiment with the Scale and Layout setting (on that same Display settings page).
