3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
Information
    • Roberto
      🛈This post originally contained file attachments which have been removed in compliance with the updated ​ Ansys Learning Forum Terms & Conditions
      Hello
      Is it possible to request this improvement?
      When I move a standard hole or go to change the size, the dimension is updated, while if I go to change the size of a threaded hole, the dimension disappears even if the center is always the same.
      Is it possible to make the quota not disappear? If not possible as an improvement it would be useful
      Regards
    • Devendra Badgujar
      Forum Moderator
      Hello Roberto
      Thanks, Roberto, for bringing this our notice, let me check if this is possible and will get back to you.
      Regards.
    • Devendra Badgujar
      Forum Moderator
      Hello Roberto
      I have raised a Bug 805647 for this issue, will get back to you once I have more information from the developers on this.
      Regards.
      • Roberto
        Devendra Badgujar Thank you ?
