Discovery Import
Discovery Import
Information
    • rg
      Hello I would like to understand how these commands work, could you send me a video to show me the difference? Best Regards
    • Devendra Badgujar
      Hello Roberto
      I am looking into this and will get back to you soon.
      Regards.
    • Devendra Badgujar
      Hi Roberto The difference between this commands are: In Default, The Move handle orientation is determined by the object(s) you select and it does not save it for future sessions. In Global, Saves the current Move handle orientation, and this orientation is used for all objects in your entire model that you are working with. In Per Object, Saves the current Move handle orientation for the selected object. When you select the object again with the Move tool active, the Move handle will be oriented at its saved orientation. This is valid for only the particular object that you have saved the orientation for and not for all other objects. Important point is click on ''Remember Orientation'' when you select these commands to save the orientation. The working of this commands is explained in the attached video. Regards.
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • rg
      Hello Devendra Badgujar Thank you very much!
Viewing 3 reply threads
