Ansys Free Student Software
Information about the analysis system ‘Fluid Flow – Icing (Fluent)’
    • Jyde
      I have ANSYS 2019 R1 with the Fensap Ice Licence. I read the ANSYS FENSAP-ICE Tutorial Guide and i learn i can use the analysis system 'Fluid Flow - Icing (Fluent)' to simulate ice acccreation but i can find this module in workbench. How can i have access to it to test it with my case of study?
      Best regards,
      Jean-Yves
    • tsiriaks
      Hello Jean-Yves,
      Please see the following note from FENSAP-ICE in Workbench Guide
      Note:  By default, Workbench does not come pre-loaded with the FENSAP-ICE Analysis Systems. The installation of the FENSAP-ICE Workbench plugin is required. In ANSYS Workbench, select Install Extensions under the Extensions menu bar. Select the FENSAPICE-WB.wbex file located in the installation package ../fensapice/workbench subdirectory. A dialog box appears to confirm the installation of the plugin. Once confirmed, select Manage Extensions under the Extensions menu. Inside the Extensions Manager, check-mark the FENSAP-ICE plugin and right-click to select Load as default. Close the Extensions Manager. The FENSAP-ICE Analysis Systems should now appear in the Toolbox window of Workbench.
      Thanks,
      Win
    • Jyde
      Hello Win,
      Thank you!
      Best Regards,
      Jean-Yves
    • tsiriaks
      Hello Jean-Yves,
      If this helps, please mark this thread as 'resolved' ("Is Solution") , so others know that there is a resolution for this issue.
      Thanks,
      Win
    • ZhandosBaizhuma
      Best regards,
      Jean-Yves
       Hello! Please can you tell me how to find  "ANSYS FENSAP-ICE Tutorial Guide"?
      Best,
      Zhandos
    • tsiriaks
Viewing 5 reply threads
