October 3, 2019 at 2:25 pm
October 4, 2019 at 1:20 am
Brian Bueno
Ansys EmployeeRoberto This setting is most likely new and did not exist in 2019 R1. The procedure for reverting to the old Mirror behavior is outlined in the attached PDF. Change the file path to match your current version of SpaceClaim.🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions-
October 4, 2019 at 7:01 am
rg
SubscriberBrian Bueno Hi Brian
The link you sent me to edit I don't think is of SpaceClaim essential as the file path is different.
"C:Program FilesANSYS Incv193SCDMSpaceClaim.exe" /UseLicenseMode=true
How should I change this route to be able to have that mirroring?
In this way?
"C:Program FilesANSYS Incv193SCDMSpaceClaim.exe" /noincubator="New Copy-Mirror Components"UseLicenseMode=true ??
October 4, 2019 at 1:01 pm
rg
SubscriberBrian Bueno Hi Brian, if you can please give me the correct link to enter? Thanks
October 4, 2019 at 3:47 pm
Brian Bueno
I believe you just need to add a space and then /noincubator="New Copy-Mirror Components" to that path
October 7, 2019 at 7:53 am
rg
SubscriberBrian Bueno Hi, Brian
it works thank you
3850
2629
1857
1252
600
