Tagged: acousticwaves, ansys-mechanical, pml, transient
December 21, 2022 at 12:31 pm
a_l_o
SubscriberHi folks,
I use Ansys Mechanical 2022 R2 to investigate pressure wave propagation in a Coupled Field Transient Analysis. As I want to simulate infinite behavior at the outer surfaces of my structure, i.e. no reflections, I used the condition "perfectly matched layers" (PML) for the outer "slice" of my structure (physics region set to "structural", geometry set to PML with APDL snippet "keyopt,matid,15,1"). Now I got an error and truncation:
If I am not allowed to use PML in a transient analysis: How do I inhibit pressure wave reflections at the outer surface of my solid structure? E.g., at one end of a pipe structure?
Thank you very much in advance!
December 30, 2022 at 7:08 pm
Bill Bulat
Ansys EmployeeI'm afraid that PML is only available for harmonic response analyses:
You can truncate structural media in transient analyses with a non-reflective boundary using INFIN257 which are created with the MAPDL EINFIN command:
Note however, that INFIN257 may only be used to trucate pure structural elements, not coupled field ones (SOLID226):
I have a MAPDL example that works but am so far unable to get EINFIN to create INFIN257 elements with a command object in Mechanical. If I get that working I'll share images of the project with you (company policy forbides me uploading files to the Forum).
Best,
Bill
January 11, 2023 at 1:36 pm
a_l_o
SubscriberHi Bill,
Your answer is really perfect, thank you very much! I am stilling looking into this matter at the side, so if you had any success in Mechanical, I'ld be glad if you share it here. I will also have look into INFIN257 elements!
Best regards,
alo
February 3, 2023 at 4:39 pm
Ushnish Basu
Ansys EmployeePlease note that transient elastic and acoustic PML is available in LS-DYNA:
https://lsdyna.ansys.com/pml/
2146
1357
1144
462
