Discovery Import
Discovery Import
Initial condition of fluid analysis
    • yaginuma.keito.yd
      Which body or face is the initial condition in transient analysis of fluid analysis?
    • yaginuma.keito.yd
      • Naresh Patre
        Keito Yaginuma
        The initial conditions are defined for the physics region and serve as a starting point for the simulation.
        If you are interested in how the time-dependent flow field evolves from a known set of initial conditions, you must specify these initial conditions correctly. If you are interested in simulating longer-term time-dependent behavior which does not depend directly on the initial conditions, such as transient vortex shading, you may want to choose Automatic initialization.
      • yaginuma.keito.yd
        Naresh Patre Thank you !!
