February 6, 2021 at 1:33 pm
AbelBerhanemeskel
SubscriberHi Everyone,
I was trying to model the initial imperfection using the eigenvalue buckling mode shape but I got confused about the scale factor. Is the scale factor the amplitude at the maximum buckled shape of the chosen mode? or should we just let the scale factor be 1? If the scale factor is indeed the amplitude does our choice of units come into consideration when we are applying it?
Thanks
February 8, 2021 at 12:32 pmAshish Khemka
Ansys EmployeennPlease refer to the following excerpt from the Ansys Help (https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v201/en/wb_sim/ds_geo_from_def.html)nScale Factor: this property scales the displacements of the initial configuration. If Scale Factor is 1.0, the full displacement value will be added to each node, 0.5, half the displacement value will be added, and so on. Negative Scale Factor values subtract the displacements and reverse the direction of deformation.nRegards,nAshish KhemkanViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- Solver Pivot Warning in Beam Element Model
5326
3311
2471
