TAGGED: ansys-mechanical-apdl, ansys-thermal, transient
October 20, 2023 at 4:23 pm
Jeremy
SubscriberI am working on are initial temperature problem using the transient thermal module.
To assign initial temperature in different locations,
- Calculate an initial temperature rise.
- Create little volumes in CAD for the intended temperature distribution.
- Create Named sections for each volume in the module.
- Assign an average temperature for each little volume using APDL command: CMSEL,s,volumename, and IC, volumename, TEMP, temperaturevalue.
Instead of performing the above, can ANSYS import using a temperature field function T(x,z) or T(x,y,z) as an initial temperature condition?
October 21, 2023 at 10:26 am
Subscriber-
October 23, 2023 at 5:27 am
Jeremy
SubscriberGreat, thanks! Got it to work!
- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3155
1688
1478
