July 31, 2019 at 9:32 am
AnthonyL
SubscriberHello,
I would like to set the initial condition of my model as a function in order to simulate the cooling of a cylinder with heterogeneous temperature.
The temperature of each point of the solid should be given by something like this:
f( sqrt((x)^2+(y)^2+(z)^2)) )
Where f is a user defined function and x,y,z are the coordinates of the point in 3D, in my case it is a text file containing temperature as a function of distance.
In Ansys AIM I can't find an option to set the temperature other than a fixed homogeneous temperature (see attached picture)
Any idea on how to proceed ?
Thanks
Anthony
August 2, 2019 at 12:40 pm
rachels1001
SubscriberHey AnthonyL,
I'd suggest creating a UDF to input this as a boundary condition.
Once you have that UDF, you can create a for loop that loops over the cells in the face. You can then define a coordinate system to the face, and define the temperature accordingly. So for example:
thread = Lookup_Thread(subdomain,ID);
face_t f;
real temper = 0.0;
real xL,yL,zL /*this defines coordinate system variables for you */
real xC{ND_ND]; /*this defines the array that the coordinate system function will fill for you */
begin_f_loop(f,thread)
F_CENTROID(xc,f,thread); /*this populates your array with the coordinate points of the centroid of one cell in your face thread */
xL = xc[0];
yL = xc[1];
zL = xc[2]; /*this retrieves the array values as variables you can now work with */
temper = sqrt((xL)^2 + (yL)^2 + (zL)^2)); /*this defines a temperature value based on the centroid coordinates */
after this point you would need a function that could define the temperature of the cell in that face, I don't know one off the top of my head but there should be one within the documentations, you would just use the temper variable you initialized earlier.
Does anyone else know a function that does this?
This is just a basic guess on my part, but let me know if this helps!
August 2, 2019 at 1:46 pm
rachels1001
SubscriberSo as an update, you could use the F_Profile function to define the temperature of the individual cell. Below is a sample UDF that does the same thing with pressure:
DEFINE_PROFILE(pressure_profile,t,i)
real x[ND_ND]; /* this will hold the position vector */
real y;
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
y = x[1];
F_PROFILE(f,t,i) = 1.1e5 - y*y/(.0745*.0745)*0.1e5;
end_f_loop(f,t)
August 15, 2019 at 1:13 pm
AnthonyL
SubscriberThanks a lot for your answers it was very helpful,
I managed to set up the temperature as a function of position for my model with the UDF you provided above,
I also switched to fluent to solve the transient thermal problem
One thing that confuses me is if I set that function as boundary condition won't it be applied at all times ? I only want this function a t=0s the rest of the time the temperature is mostly controlled by radiation and thermal conduction.
August 16, 2019 at 2:00 pm
AnthonyL
SubscriberOk So I used your code above and changed DEFINE_PROFILE to DEFINE_INIT which is run once at the beginning of the simulation.
This gives me the case needed.
2524
2066
1279
1096
457
