Ansys Products
Ansys Products
Initialize Electronic Desktop from terminal – OS installation
    • tomas.monopoli
      Dear Ansys,
      In order to run script ipy files, the first step is to import the ScriptEnv from the PythonFiles folder and PythonFiles/DesktopPlugin. This works perfectly fine in windows OS. However I am not able to run ScriptEnv.Initialize() from my Centos7 computer. Probably the progID is not valid in Linux?
      Also ScriptEnv.InitializeNew() is specifically only allowed for windows system, as there is a statement in the function that checks the OS type.
      However, the scripts work correctly when launched from the graphic interface. Is there a way to launch scripts directly from the terminal?
      Thank you,
      Tomas
Viewing 0 reply threads
