May 3, 2022 at 11:50 am
isaps1860
SubscriberI have a long slot with small distances. So if I mesh this slot as a inlet boundary condition I get a very high number of elements. Is it possible to set this condition for example as a line inlet boundary condition or something like that? So that I can reduce the number of elements?
Best regards
May 3, 2022 at 12:40 pmNikhil Narale
Ansys EmployeeHello,
For 3d case, you have to assign boundary conditions to the 2d faces. Having said that, you have to mesh the face and assign boundary condition to it.
However, you can play with the mesh and different sizing options if you want to reduce the number of elements.
Nikhil
May 3, 2022 at 1:06 pmRob
Forum ModeratorPlease post an image. There are a few tricks, but it's difficult to explain without breaking the rules (export law) and knowing more.
May 3, 2022 at 1:26 pmMay 3, 2022 at 2:30 pmRob
Forum ModeratorIf it had been several slots we can cheat. Looking at the above it's not so easy as it could significantly influence the airflow downstream. What flow boundary are you needing to put on the surface?
May 3, 2022 at 2:39 pmisaps1860
SubscriberThere┬┤s a second slot on the other side of the vehicle, which is also as long as the one above on the image.
I already thought that this will be not easy to solve...The surface should be a velocity inlet with a profile of measured velocities along the slot.
May 3, 2022 at 3:59 pmRob
Forum ModeratorWhich may have a significant effect on the flow in that area: read up on boundary layer separation.
May 4, 2022 at 6:43 amisaps1860
SubscriberAlright, thank youViewing 7 reply threads- You must be logged in to reply to this topic.
Trending discussions- Floating point exception in Fluent
- Using GPU in FLUENT
8786
4658
3151
1680
1468
