inlet problem
    • TAHA BOUGHLAF
      the problem is to define diffferent inlet condition during the mesh I define 10 inlet (pic1) but during the configuration I get only one inlet
      Please can you post an image of the geometry both in Fluent Meshing and the solver.
    • TAHA BOUGHLAF
    • TAHA BOUGHLAF
      Can you check the surface mesh and settings beyond that, have you merged any zones?
    • TAHA BOUGHLAF
      no i didn'y do i just had done the mesh and go directly for doing the settings
      • NickFL
        Are the rest of them hiding under walls?
      Not sure. Assuming you can display the surfaces in Meshing they ought to pass over to the solver. Have a look at Domain>Zones>Separate Faces as an alternative in the solver.
Viewing 6 reply threads
