August 28, 2023 at 3:37 am
namrata mishra
SubscriberHii
I am using a UDF at the inlet to simulate wind flow inside the domain. Now, I need this wind profile at 30 degrees to the inlet. how can i specify angle in my boundary conditions without changing the udf. I am attaching some screenshots for reference.
Also, I chose velocity specification method normal to boundary. If I change it to magnitude and direction, I cant clearly understand what to specify in X, Y and Z directions.
August 28, 2023 at 4:31 am
SRP
Ansys EmployeeHi,
You need to make changes in the UDF itself to make flow at 30 degree or make an expression at the inlet corresponding to 30 degree.
Thank you.
August 28, 2023 at 4:49 am
namrata mishra
SubscriberOk. Can you please suggest me what changes do I need to make . My udf code is as follows:
#include "udf.h"#define UREF 4.7/* ref. speed 3.0 m/s */#define CMU 0.09#define H 12#define u_star 0.52#define delta 36#define p_constant 0.4DEFINE_PROFILE(velocity_profile, thread, position){float x[ND_ND];float y;float u_in;face_t f;begin_f_loop(f, thread){F_CENTROID(x,f,thread);y=x[1];u_in = UREF*pow(y/H,0.3);F_PROFILE(f,thread,position) = u_in;}end_f_loop(f, thread)}/* profile for kinetic energy */DEFINE_PROFILE(k_profile, thread, position){float x[ND_ND];face_t f;float y;float k;begin_f_loop(f, thread){F_CENTROID(x,f,thread);y=x[1];k=(u_star*u_star/pow(CMU,0.5))*(1-(y/delta));F_PROFILE(f,thread,position)=k;}end_f_loop(f, thread)}/* profile for dissipation rate */DEFINE_PROFILE(dissip_profile, thread, position){float x[ND_ND];face_t f;float y;float eps;begin_f_loop(f, thread){F_CENTROID(x,f,thread);y=x[1];eps=(pow(u_star,3)/(p_constant*y))*(1-(y/delta));F_PROFILE(f,thread,position)=eps;}end_f_loop(f,thread)} -
August 29, 2023 at 2:22 pm
Ansys EmployeeChange to "components" rather than magnitude normal to boundary. You then need two DEFINE_PROFILE(velocity_profile, thread, position) blocks for the two components. Hint, don't call them both "velocity_profile".
7592
4440
2953
1427
1322
