October 11, 2018 at 7:00 pm
RCamp
SubscriberHi all,
I am working on developing a mesh for a Fluent simulation. I have attached a picture below and as can be seen the surface mesh seems pretty uniform however, I am new to CFD and am curious if the inner mesh looks acceptable? It seems rather messy to my beginners eye. Additionally, I would really like to make the inner region of the column mesh finer compared to the outer region, is that possible?
Thank you.
October 11, 2018 at 7:12 pm
raul.raghav
SubscriberSee the youtube tutorial attached below. It shows multiple ways of meshing a cylindrical geometry.
ANSYS MESHING - Multizone + Inflation
October 11, 2018 at 8:24 pm
October 11, 2018 at 9:19 pm
raul.raghav
SubscriberDelete the “Patch Conforming Method” under “Mesh”. -
October 11, 2018 at 11:01 pm
RCamp
SubscriberI tried this and am still having the same issue. The only time it will run is when I have the patch conforming on but then the inflation is not doing anything.
October 12, 2018 at 12:42 am
raul.raghav
SubscriberDoes your geometry consist of multiple cylinders?
October 12, 2018 at 12:48 am
October 12, 2018 at 9:04 am
Rahul Kumbhar
Ansys EmployeeHi Rcamp,
Insert sweep mesh method for the body and select inflation scoped face as a 'Source' face in the mesh method.
Thanks
Rahul
October 12, 2018 at 1:22 pm
raul.raghav
SubscriberYou can also use Multizone+Inflation to create a good quality mesh. Look at the attached video tutorial for reference.
If you can provide a cross-sectional view (XY or ZY planes) of your geometry, we would be able to guide you better.
October 12, 2018 at 4:23 pm
October 12, 2018 at 8:21 pm
RCamp
SubscriberAgain I am trying to make the core of this column's mesh finer. Is there a way to do that? All I can find is how inflation is used to make the mesh directly below the surface finer and this doesn't help me.
Thanks.
-RCamp
October 15, 2018 at 2:46 pm
Ansys EmployeeYou can select surfaces in mesh and right-click to add a local sizing. I'd also look at the shape and decide if all of the features are needed as you need to resolve anything you include in the model to see their effect on the flow.
October 19, 2018 at 2:51 pm
RCamp
SubscriberIs it possible to local size changes within the mesh and not just on the surface?
October 19, 2018 at 4:32 pm
Ansys EmployeeYes, but you'd need to split a volume out to do this (or use a Body of Influence). Read up on volume decomposition.
November 29, 2018 at 10:48 am
HarishKolla
SubscriberHello
can you suggest sources to get proper knowledge on meshing
November 29, 2018 at 12:45 pm
SubscriberHarish, this discussion is marked as Solved. Please post a New Discussion to ask questions. Did you try looking in the Tutorials listed in the site categories?
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1345
1118
461
